Just got my Skr Pro and TFT35 wired and everything moves nicely.
Maybe this is a dumb question but which way does the z-axis go? As z moves down is that more positive or negative? The down icon on the TFT35 shows a Z+ below it, so I’m assuming the larger Z is the lower the z-axis is.
The reason I ask is that all my motors are wired the same and they all move in the correct direct except Z. I put JST connectors on my motor cables so they are not easily flipped.
I solved the problem by using Settings->Features->Invert Z Axis. My question is this expected?
Thanks.
All
