Hello everyone, i have started cutting bits out of MDF on my MPCNC, i was wondering if anyone has designed up any wipers for it?? starting to get a little bit of build up on my bearings every now and then…
cheers
Look for “schmutz cover” on thingiverse. I can’t remember who made them. Some old guy coding? I swear I have the memory of a goldfish these days.
Made these up from TPU, will get them uploaded to thingiverse, XY wiper I just glued on with seal all. but has option to screw on.
Did you ever upload these anywhere? I’m getting so clogged up cutting MDF the steppers are skipping.
(Hoping you have notifications on since this was a while ago)
Hello,
They are located here: MPCNC wipers by CToner - Thingiverse
might have to modify wipers on back side of x & y, little trouble getting them to stay on as so thin.
has not caused me an issue when not there, at this time
Hope this helps
That’s great, thanks.
I note that the wipers from @claytoner are for Burly trucks. Does anyone have them for Primo trucks? Also, any solutions for wiping the rails in the Z axis assembly? The Z rails and bearings are much harder to clean when sawdust gets rolled onto them.
Hello, I’m not sure if I did upload… I will check and send a link…
