After following the instructions to wire the stepper motors in series the machine only jerks in place. What baffles me is if I connect the Y motors to the Z axis outlets (one in each) the machine goes on its course normally. I’ve tried reversing the wiring to one of the motors and the result is the same.
A link to a couple of videos showcasing the problem
Is that a real rambo, or clone? The motor is acting like it’s wired incorrectly, so if it’s a clone, that’s the issue. We’ve had a bunch of clones do this. If it’s a real rambo, either bought from here or directly from ultimachine, then you’ve got a pin that’s either intermittent, or is loose in the connector.
You helped me, indirectly, resolve the issue. I’ve started by checking the pins on the board, they are solid. Then I changed the dupont connector, and one of them was faulty. I’ll now resume the search for the next problem =)
