Hello
What do you advice for max z height.
The size is 50cm x 50cm
Tnx
Hello
Tnx
I’m assuming you’re thinking of CNC, not 3D printing? The longer, the more flex there will be. Keep in mind also that standard bits are like 3cm long. It should be pretty stiff at 6-9cm. Also if you use the conduit legs, it’s just the legs, the z axis and the screw that need to be replaced if you make it bigger.
