I in need of some help.
I have made a 100mm square square test cut to check the accuracy of of my mpcncs. It’s exporting correctly from my design program. I made a grid of the exact same size in Estlecam to verify the size in estlecam. Then use repetier to create gcode. However when I cut it its not perfectly square. More of a rectangle. It’s off by 2mm. Any ideas why this this is happening?
All toothed pullies are identical.
