I have weird jitter in only one axis that I cannot seem to figure out. I have spent hours trying various solutions and isolating possible culprits, but still no luck. Starting to get a little frustrated.
I’ve swapped outputs on the RAMPS using the “smooth” y-axis, but no luck. So its not the driver or how the driver is tuned.
I’ve squared the frame many, many, many times. I’ve also loosened and tightened all of the “long” bolts that affect bearing preloads. Also tried belts tight and loose…no difference.
Also tried moving motors to see if maybe it was a bad stepper, but nothing. Still stays true to only this axis.
Here is a video of what I’m talking about. Very odd. It almost seems like the deceleration in the firmware is causing an issue, yet that doesn’t explain why one axis is perfect and the other is most certainly not.
