I recently started printing the parts to make the MPCNC.
The XY component reads 201 grams on the parts list but it is slicing at 168 grams on my end with 55% infill. 1x scale. 23.5mm model.
I just wanted to make sure I wasn’t missing something. I expect a design change has occurred and the list wasn’t updated.
I just sliced the XY part using Cura 3 and found that the weight depended on the infill pattern but 168 grams is a reasonable number. I assume you are using 3 perimeters.
Thank you very much for checking.
I did use 3 perimeters.
