Yet another Repetier Problem
Hi guys,
Having trouble connecting Repetier Host to MPCNC. Actions so far:
  1. Installed CH340 Windows 8 drivers
  2. Resistor installed on T0
  3. Tried Pronterface - no connection also.
  4. Repetier Server uninstalled
  5. Checked voltages on board
Using Ardunio Mega/RAMPS 1.4 boards purchased through Vicious site.
I can make the make the stepper motors move using the RAMPS testing program in Arduino IDE.
When connecting through Repetier I get a "Connection Timeout’ error. Pronterface just says connecting.
I would appreciate any help.
Regards,
Jamie
Check your baud rate in repetier, My firmware is set to 250,000, unless you changed it.
