Z axis alignment tips
I put a 3d print head on my mpcnc and it has made it obvious that my z axis isn’t aligned right. Any tips for troubleshooting/ adjusting? It looks to me like the rod isn’t aligned quite right with the stepper motor.
Thanks!
Not sure what that means exactly.
The best way to fix the center issue is take apart the center assembly and put it back together, triple checking everything as you go.
Sorry, that was a horrible description. I took apart the z axis and the conduit wasn’t parallel. It seems like everything is good abs I am almost done printing my mp3dp parts.
Thanks
