z-axis bearing bolts
do you all have the threaded rod so close the bearings?
i turned those bolts a bit on lathe so that i have little more clearance.
Hi.
I had issues with the threaded rod fouling on the bolt heads too (IE version) but I just spaced the z nut holder out slightly with some washers. Hasn’t caused any issues so far.
