Hello All,
I have been working on making some signs and plaques while learning and fine tuning my new MPCNC.
Smaller jobs are working fairly well. The problem that I am having appears to manifest at the latter part of longer running jobs.
I don’t know if it is relative to the actual duration or due to the location of the gantry. On larger jobs I am working further along the X axis than I am on shorter jobs. I have trouble seeing gantry location affecting Z axis though…
The jobs start well an I sit an watch closely as everything behaves well. Then my attention begins to wander. I look away and I hear that “off” sound of a stepper skipping or binding. I look and everything looks fine except, maybe, the letters are now carving a bit deeper. Then it happens again and the failure is obvious as the clearance move (z axis) and the cutter does not come up above the surface of the workpiece and then moves to its next location while cutting a swath across the face of my project.
In short, it is failing to make positive Z axis moves after about 30 minutes of carving and when the toolpath has reached a point that is about midway on the X axis.
The Z axis has no trouble on smaller/shorter jobs. The difference that I can see are limited to duration of job and working distance down the X axis.
What do you all think? Suggestions?
Thanks.
S.
