-Vicious 1 board
-Machine has worked multiple times without a flaw
-No End stops connected
I have been using the Repeteir Host and the z axis for some reason keeps only going one direction(up) no matter what Z Direction I want it to go.
I have disconnected and reconnected but it is not solved by resetting but instead it is sporadic and only when I disconnect the actual power cord to the stepper and I reconnect it will it work (not every time though).
I think it might be a stepper driver but I don’t know why it works sometimes and not others… any help would be great
As you can see it works …just can’t figure out why it will change mid run or even when I am just manually controlling it
