So, I’m getting movement in this MPCNC build. However, there seems to be a surprise that I don’t understand.
First, the hardware:
X and Y axes are using the stepper motors from V1Engineering
Z is using a different one because V1 only had 4 and is now sold out. The one it’s using has the typical 1.8 degrees per step. The leadscrew is from V1 Engineering, therefore 8mm/revolution. The motors are all 3 set for 32 microsteps. The Marlin is essentially Ryan’s version, with a different Motherboard (MKS Gen L v1.0) The line defining the steps is:
By my calculation, (32 microsteps/step)(200 step/Revolution)(1 revolution/8mm) gives 800 steps per mm, as is being used.
However, sending commands from the RepRap Controller
(#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER) causes about half the correct travel on the z-axis. In other words, I send a command to move 10mm and it only moves about 5 mm.
Obviously, I could change the steps/mm, but why would this be necessary?
Or perhaps you don’t have the correct number of steps selected with the jumpers for your drivers. You need all three jumpers installed to get 32 steps.
@billsey - if he used less than 3 jumpers, he would get more travel rather than less per step, so I don’t think that’s it.
The other thing that would be easy to check is that the leadscrew is 8mm/rotation. Ryan does a great job with quality control of his subvendors, so I doubt that is it, but it’s easy to check. Other than the stepper motor and the leadscrew, I think you’re down to recompiling and reflashing the firmware with the steps/mm settings you have above.
The first thing I checked was the angular step size. Specifications at Amazon are clear, but, there was a specification card with the motor. I should check that too. From Amazon:
Manufacturer Part Number: 17HS19-2004S1
Motor Type: Bipolar Stepper
Step Angle: 1.8 deg.
Holding Torque: 59Ncm(83.6oz.in)
Rated Current/phase: 2.0A
Phase Resistance: 1.4ohms
Inductance: 3.0mH+/-20%(1KHz)
Physical Specification:
Frame Size: 42 x 42mm
Body Length: 48mm
Shaft Diameter: 5mm
Shaft Length: 24mm
D-cut Length: 15mm
Number of Leads: 4
Lead Length: 1m with connector
Weight: 390g
As for the jumpers, the MKS Gen L board has jumpers in all three positions. They’ve not been touched.
Good idea to confirm the travel per rotation. It IS easy to check.
I also thought about connecting the z-stepper to the x or y driver, which is set for 200 steps per mm since it’s a belt. That result should point to either the leadscrew or the motor.
Well, this one is just going to be a mystery I guess, at least for now. When I went back and connected all the stepping motors, the movement on the z axis is now OK. I literally didn’t change anything … Simply went ahead and connected x and y as well as z. Before, it had been z only.
In fact I would think that I had just been mistaken, but I had been able to reproduce the problem exactly multiple times.
Easiest way I found to fix this is to take Actual distance / distance commanded and multiply that by your current z-steps / mm in firmware. I just had this issue with the new Rambo. Used a drop gauge and lowered z by 10 mm at a time, averaged, uploaded new firmware, checked again and by the 2nd time I had repeatable accuracy below what my gauge could measure.
