I feel like my brain is vapor locked right now. Fortunately, I’ve collected some data which may help…
- Using SKR PRO V1.2 from V1Engineering.
- XY and Z axes all work as expected.
- Using V1Pi on a Raspberry Pi 3 B+ connected to SKR PRO V1.2 via Ethernet cable. Using CNC.JS to control and gather info.
- Touch plate is connected to the proper connector on the SKR PRO and verified by using the G119 command:
Ground lead (alligator clip) not touching the touch plate.
> M119
Reporting endstop status
X_min: open
Y_min: open
Z_min: open
ok
Ground lead (alligator clip) touching the touch plate.
> M119
X_min: open
Y_min: open
Z_min: TRIGGERED
ok
> - Also verified physical connection to the Z_min connector by touching the ground lead to the touch plate and verifying that the red LED
associated with the Z stepper motor flashed on and off (off) when the ground lead touched the touch plate. - When I attempt to run the G38.2 command, or any of the G38 commands for that matter…
> G38.2 Z10 F20
Echo:Unknown command: “G38.2 Z10 F20”
ok
> - I am not using, nor do I have endstops installed on the X or Y axes.
- Can I used the Probe widget on CNC.JS to test the touch plate after it is enabled (assuming that’s what’s wrong and someone is
going to explain how to correct the problem)?
Sorry, this is just one of those days when I feel totally brain dead. Probably shouldn’t be working on this stuff and promise to stop if I can just get over this hurdle.
Thanks in advance!
