I am slowly getting familiar with my new Lowrider. I have successfully completed a couple projects but occasionally I mess up and need to stop a job before it finishes. When I hit cancel in Octoprint it stops the job but it also disables the steppers and the bit plunges all the way down. So far it hasn’t caused any issues but is there something I can add in Octoprint to keep the steppers enabled after I cancel a job?
There are gcode snippets in the octoprint settings. If you see M84, then it is disabling the steppers.
Yup, found it. Thank you!
