I’m starting to assembly my very first MPCNC. I’m planning to use this machine for milling wood but also need some aluminium parts crafted from time to time. Now I’m trying to find some balance between travel length and rigidity of the machine. I ended up with X and Y dimensions of 864 mm x 1,164 mm (longer axis will be supported from the middle).
The needed Z axis height got me confused. I’m using Cut Calculator and there’s an input for Z-Axis Desired Work Height. I try to aim for as rigid machine as possible for this size so the Z axis would need to be on the short side. My question is: What I need to include in the desired work height dimension? Naturally milled material thickness will be there but do I also need to calculate endmill height or some other factors along with this (a little bit of empty space between endmill and worked material et cetera…)?
