Hello,
I have implemented a z probe using the Z1 S- on the rambo card, and it works !.
I use the menu V1 custom > home Z and it does the homing with the probe plate I use.
My question is where can I define in Marlin the thickness of my probe plate which is 1 mm ?
Thanks
Marlin does not have a probe thickness setting. You have to adjust the height using g-code. Typically, the g-code for a touch plate is:
G28 Z ; Home Z G92 Z1.0 ; Set current offset to 1.0mm for Z G0 Z5 F480 ; Lift Z to allow touch plate to be removed
You can run this code from a file on the SD card, or attach it to a custom button in Repetier-Host. You can also fix the V1 custom menu, but it requires a small edit to marlin with a compile and a reflash of your control board.
In configuration.adv.h, find the following two lines:
#define MAIN_MENU_ITEM_2_DESC "Home Z Axis" // "Preheat for " PREHEAT_1_LABEL #define MAIN_MENU_ITEM_2_GCODE "G28 Z" // "M140 S" STRINGIFY(PREHEAT_1_TEMP_BED) "\nM104 S" STRINGIFY(PREHEAT_1_TEMP_HOTEND)
They can be changed to:
#define MAIN_MENU_ITEM_2_DESC "Home Z Axis" #define MAIN_MENU_ITEM_2_GCODE "G28 Z\nG92 Z1.0\nG0 Z5 F480"
Removing the text after the β//β is optional.
Dear Robert,
Thanks for your reply. I did the mod for MAIN_MENU_ITEM_2_GCODE and reflashed marlin again.
It seems that it is the same cause once I did use the probe plate to set my Z, on the main menu Z is 0 but it should be 1 ? isnβt it ? The goal is to tell the machine that 0 is 1mm below (cause my probe plate is 1mm height)β¦
After few tries it works. It seems that I had an issue with the flashing process.
So 0 is set correctly and after probing it goes at Z 5mm to allow to remove the plate .
Thanks a lot
Also a pause command I found out was helpful.
Robert always has the answers haha
