The Z tubes keep rubbing on one side of the table when moving in the Y dir. This occurs towards the end of the table. The table is a sheet of ply & yup is it’s perfectly square.
I’m thinking the LowRider is out of square even though I measured each X- tube distance from Y-Axis bracket to bracket on both fore and aft X-Tube.
Q. Is there a particular method one uses to square up the entire LR machine ?
If you’re looking for your “z tube” to get a table rub, look under massage parlors, not machine cutters. Things could get messy, in the screamy, traumatic ways. Well, more likely to…
