After searching the forums, my head is spinning a bit from lots of theory, potential issues noted between slicers(etc.), and some apparent lessons learned that aren’t vetted in the FAQs yet, so I would like to confirm… I’m about to print my first build, and was really hoping someone can help me confirm my setup before I start trying to print parts this week-
My Data:
I’m not an avid 3D Print user and have only done it a few times, so any basic info would be much appreciated! If it helps, I have a CR-10S with TH3D firmware load, and I’ve used CURA a couple of times now. .4mm nozzle and I have verified the 150XY_mm bed test (basic) is spot on in the X, Y, and the Diagonal.
Questions:
What slicer is recommended? i.e. with alleged differences with belt gap spacing last summer, and variable infill recommendations (which I don’t see supported in CURA), I want to know which slicer is my best/safest option to help get it right the first time? (i.e. less about opinions, power user considerations, etc.). I’m willing to learn a new slicer. I just don’t see a place in Cura to even manually capture a 70%/30%/70% split at 24mm and 116mm for the core?
Specific Recommended Settings?
For all the parts other than the core, is the only real setting that matters is a 70% infill, and a layer height of .3mm being optimal for my standard .4mm nozzle since this will be stronger and more rigid than a .2mm or .25mm layer height?-
Any other key settings? Perimeters/walls = 3 good enough? Any other settings?
Settings for the Core, vice the other parts
I know I have lots of questions, and I haven’t touched this 3D printer in several years… no doubt I’ve missed out on a lot that is likely regarded as common knowledge at this point… A huge thanks in advance for anyone willing to take the time to help me out!
