I’ve seen some spindles on Amazon that have a 0-10v input that seems to control speed (called mach 3 input for mach 3 software I assume)
Can we take advantage of this to control speed using the Rambo board?
Not directly. I don’t think the Rambo can do 0-10V TTL output. But I’m sure you can get a converter board that will take the 3.3V or 5V TTL signal from the Rambo, and boost it to 10V.
here’s one I’ve been using successfully, if you dont mind soldering
https://easyeda.com/ninetailfox97/vfd-adapter
