Trying to use my MPCNC as a 3D Printer, How do I add a extruder and heated build plate and using dual endstops I am using the Archium 1 Board
You can’t. Not enough motor drivers.
Bmmer, what other board should I use
With dual endstops, I don’t think there is one. You could go with a duet with an expansion board, but no one has done that as far as I know.
OK Thanks Barry
You can switch one axis to series and still print though.
And someday you could use the SKR Pro since it has six drivers. Software requires some tweaking though, since we don’t have a prebuilt version.
