I’m not sure how big your primo is, but you can safely get away with 0.001" per tooth, 0.03" depth per pass at full rippem.
If you are going to attempt a slot, cut a couple roughing passes on each depth and finish only at final. The two roughing passes will give extra room for the chip to clear and finishing only at final depth will get you a better finish.
Affirmatively, offset the shape in the design workspace and use that to constrain an adaptive path, same parameters, 0.03 optimal load. Change the lead in/lead out to the same feed as the cut rate.
If this are going well you can override the feed rate to speed things up. Double that speed is attainable on a reasonable primo, so for a one and done part, this is a good way to get the best balance.
If your primo is extra small and rigid, go 0.04 deep and shoot for 0.0015 per tooth. You can override the feed to a slower speed at run time if that turns out too aggressive, but if you’re rigid the depth should still be ok.
GOOD LUCK!
Edit: I hope you got the short single flute. It can do this job easily. I’ve not had much luck at any speed in aluminum with the longer single flute, but folks who have (that I’m aware of) were much less aggressive with that one.
