I’m sure its been gone over time and time again. But here is goes, looking to cut a part out of aluminum in Estlcam V11.013. Its a 2 two side 3d model. Ill be using the Block Machining option. IM running the DW660 but cant seem to to get the right settings down. Whats a good place to start on speed, depth per pass, etc.
listed below is what I have and what im working on.
I would mill that as a regular job using a flip. I don’t really see anything that is specifically 3D about it other than it is two sided.
As for speeds and stuff, You need to give all the details of your machine specs, spindle, and endmill. I would definitely mill it out of wood or plastic first, that is not the job to figure out your Aluminum settings and a flip.
