So I want to replace the RAMPS board in my ZenXY table and replace it with this. I know Ryan has done the firmware for this, but being new to GRBL, I’m not as familiar with how to do stuff. Also want to connect it to the home wifi, so I don’t have to sneakernet files to it.
I don’t know if those come pre-flashed or not. I’m not using any of Bart’s hardware. But once you plug the ESP32 into the carrier board and power it up, it should be broadcasting a wifi signal. Connect to that with your phone, tablet, laptop, etc.
Instructions are here…
Ok… so no, mine is not flashed. There was the option to include a flashed ESP32 module, but I’m using ones spurced elsewhere (I bought a 6 pack, lol. I wanted to be able to try some other stuff.)
I did pull the .zip that Ryan posted. I guess I’ll need to compile it. Looks like platformio is the way to do that. Also appears as though the SSID and password for the wifi can be entered into the config, so I’ll look at that.
With the ESP32 boards, when you compile and upload, you need to hold down the “boot” button on the board when the console shows the Connecting...___...___... prompt. (It should show 3 periods and 3 underscores alternating, I can’t figure out how to make that come through here. It keep bolding the middle periods with the markups)
…___…___…
Technically, it is bolding and italicizing the three periods in the middle, it’s just really, really hard to see the italics… (one underscore italicizes, two underscores bolds, three underscores bolds and italicizes)
Use backslashes to escape the underscores. …\_\_\_…\_\_\_… → …___…___…
Or use backticks to escape/console-ize the whole shebang `…___…___…` → ...___...___...
I don’t know why, but recently I have not had to place the device in programming mode when uploading, it just accepts the upload without the “hold down the boot button and click the reset button to get into program mode”… but that is another story.
You can also just use the arduino IDE to upload to your ESP32 DEVKIT.
Unless you enter credentials in config.h the ESP32 will set up its own wifi network that you can connect to and then configure the esp32 to attach to your home network - or…
You can enter your ssid and password to your home network in the config.h file… around line 95 …so it connects automagically upon booting.
I haven’t ever held down the boot button on an esp32, just the esp8266s.
I usually use platformio from the command line, but I have also used the arduino ide (but a long time ago, like a year). I also only use Linux, but I don’t think that should matter, unless the usb to uart chipset needs drivers in windows.
It appears that some of the dodgy ESP32 devkits do not have the two transistors to toggle EN and GPIO0 when the USB signals it is ready to upload, these will require the pressing of the boot and reset buttons…
I must have had a new delivery of up-market devices!
I did have to hold down a button… Or would have, but I used a jumper wire instead.
I still haven’t had a chance to test the board, I’m kind of waiting on that package stuck in customs since June 19, and now I’m thinking that I might end up making a laser engraver out of it instead, having seen some cool ideas around. I have a feeling that I could probably order a laser from China by slowboat and it’d be here before I see that package… I’ve been digging up my old wishlists for 40-60W CO2 lasers…
I have my ZENXY assembled and wired to the DBring controller but I cannot seem to find where to download the firmware. OR it works just as received from BDring and I have the belts wrong.
Help!
My firmware link in that thread is dead…I am making a note to myself to upload a new one, figure out a github link so we can track changes, add it to the docs.
Sorry everyone, I have really dropped the ball with the ZEN Docs.
I’m more of a builder than a programmer, although I built a 3D printer 8 years ago, and have both the first and second versions on MPCNC running well. All that aside, I cannot for love nor money figure how to add the ZENX XY code to the Grbl_esp32-main. And once that is accomplished can it be compiled in Adruino or must I figure out IO whatever? I’m well past retirement age and things don’t absorb as well as they did 50 years ago.
Ryan has published the version he is using. He has is also trying to upload the .bin. It may take a little while to make it super user friendly. But I expect you to have no trouble figuring it out. We can help.
You should be able to download this version and then compile it using arduino ide. But you will need to install the esp32 board manager. The best instructions are in the main grbl_esp32 repo:
Sorry I forgot to post that here. I didn’t write it on my todo list, sorry bud. I got a little side tracked trying to find out how to get more of those boards.
If your board has been flashed you can do an over the air flash with the bin if not you need to just run it through platform.io. After flashing set your limits and you are good to go.
I have something to show for all the effort, but need more advice.
I have to change all the GCODE from G01 to G0 to get response.
I hooked up the optical end stops as shown somewhere with VCC on a 5 vol pin but when I send M119 I get a bad command response and of course it won’t home.
When I run the code from Sandify I have to set a travel speed or I get an error.
