I have one of the original burly MPCNC’s and I need new belts but the belts in the shop measure 10mm wide mine are measuring a little over 5mm wide are these belts in the shop now, the same as the belts that the machine originally came with?
The original belts were 6 mm, I believe.
Yeah, sorry the previous versions used 6mm. I no longer carry them, just 10mm.
The 6mm belts are common and available from many sources, but be careful to avoid the ones reinforced with steel.
Do any of you have a good source to order them?
This looks good.,
Perfect thank you, by the way I have officially broke the $2500 mark since the machine has been operational. I finished it around August.
I don’t think there is a nicer message to get. I love knowing the machine pays for itself and then starts to put more in your pocket.
I love it I just got two more orders for two sets a piece
What I love the most is that the overhead is almost non existent for starting a small business with it.
