I have always wondered what the correct belt tension should be (or feel like). And even, how to get about the same tension in all belts.
Today I built a very crude test rig to do some tests and experiment how well a frequency analyzer phone App would work in measuring belt tensions.
My test setup:
- A length of 6 mm belt. Measure length and weight of the belt.
- Drill some holes in a piece of wood in equal steps (200, 250, 300, 350mm etc.)
- Fill a canister with water to the target weight (6 lbs)
- Attach the belt to the rig and with the aid of a bearing hang the water canister from the belt (so we have a known tension on the belt).
- The belt should vibrate at a known frequency. This frequency can be calculated from the factors: weight of belt (kg/m), tension in belt (N), and span/length of belt.
- Compare measured frequency to the theoretical frequency.
Then use the App to measure and adjust the belts on my MPCNC.
