I am trying to carve out a logo thats about 14"x10". Its a pretty detailed logo and all I really want is to lower the background a bit and the perimeter. I have the 3mm selected using the “carve” method in Estlecam. It does not like that very much. When I bypass the warnings about not using a endmill the carve takes much too long to process.
I only want to relive the background by 5mm. Am I using the wrong mill or method?
With the vbit you will be able to carve or engrave on top of the lines. Go shallow (1-2 mm) for increased detail. That drawing could be simplified. For the tree part carve out the branches (inverse of what you have now).
