Hi, I have installed CNCJS on my PI4 and it wnet well. After i did the reboot I open my web browser and
typed my pi`s ip 192.168.1.76 and I got cncjs running. I shut down my PI hooked it up to my cnc machine and went back to my computer to connect. Now I can not connect to the ip to get cncjs to work…help please…
Is it possible the up address changed, or cncjs didn’t restart for some reason? Can you ssh into the rpi?
hi, Yes I can shh into the pi. I can also use my tablet over the same ip as a wireless screen
Yes that is the one.
Can you access it by typing in port 8000 at end? Like 192.168.1.76:8000
Hi, I have tried 192.168.1.76:8080 that did not work. I am now trying to install again. I wil try this if it is not working. brb
I just used @jeffeb3’s v1pi image for rpi and it just worked… so not too familiar with installing it on its own.
is ther a os file that include all I need? bahhh might try that
It has everything you need. Just download and burn it to the sd card.
do you have a direct link to the file? tnx
The link is in my post, just scroll down to the download.
Madgrizzle suggested trying port 8000.
Espen said he tried port 8080.
Possible simple mismatch?
