Hey all,
I’ve been doing research on DIY CNC machines for a while and I’ve settled on the MPCNC as my first learning experience. If all goes well I’ll fork over some money for a more serious setup once I narrow down exactly what I want to do. Right now I’m interested in cutting wood, acrylic and hopefully trying for thin aluminum (1/16 to 1/8) for signs as a small side gig.
I have a friend with a 3D printer willing to print all the parts for me at cost. I’ve been trying to figure out the other details in the meantime:
-I plan to keep my Z axis relatively low (2-4") and I’m going to start bigger with my Y and X (24"x"48 usable respectively). If this isn’t accurate enough going smaller is easier than going bigger later. Has anyone considered using a different material for the outer X and Y guide rods, I figure aluminum is too soft but what about DOM 1020 steel treated to not rust? This would prevent ANY sagging from happening with the longer X or Y axes. Thicker stainless tubes get ridiculously expensive real fast
-I know I want 304 stainless guide tubes but I was curious what most people are purchasing - seamless or welded seam? There is a difference, here is a good read http://www.hysteelpipe.com/steel-knowledge/api-5l-astm-a53-seamless-vs-welded-steel-pipe/
“The dimensional flaw of welded tubing may be its ovality, or roundness. Seamless tubing has a very round and very consistent diameter as a result of being extruded through a die, with typical measured variations in diameter of +/- 0.025mm for a 25 mm OD size. Roll formed welded tubing on the other hand, typically varies about +/- 0.050 mm to +/- 0.075 mm for the same nominal OD. However, for most applications, good concentricity is more valuable than good ovality.”
I think seamless is the best for this application due to it’s more consistent OD. Am I overthinking this though? I can easily get welded seam locally very cheap to the online stores, I can get 30’ of 1" 16 gauge A554 304 for about $50 http://www.tachen.com/catalog/pdf/pipe/A554-inch.pdf
-I’m considering running the DW660 with a rheostat control but I heard the router is very loud. Can anyone comment on this? An alternative is the Quiet Spindle but I’m concerned about its build quality. The cost difference does not matter to me. I’m thinking about buying the DW660 at a local Home Depot and returning it if it is too loud.
-What is the durability of PLA in summer heat? I plan on keeping this in my garage and live in Phoenix, AZ where the temps in my garage could easily reach 120+
I’m very excited to start building this, I’ll be posting my progress along with recording the accuracy of the machine. There seems to be very little information about this on the forums but I did read I can expect about 0.030" or ~0.7mm.
