Sorry if this has been asked before but a search yielded no joy. It seems every time I use the drill function the transit speed between holes defaults to F180, 3mm/sec which is kinda glacial. Is there somewhere to set the default transit speed in Estlcam? If not, I’ve never edited gcode in RH, is it necessary to anything other than delete/replace the speed value with whatever you choose?
