I was cutting some wood and plywood with 1 flute simple bit and it was working fine.
Some time ago I found that people prefer Diamond Bits for the plywood because they produce more clear cuts on the top. I tried a couple of bits (3.17, 2.4, and 2.1) but comparing to 1 flute 3.17 I am getting serious vibrations.
Do you have any quess what is the reason and what am I doing wrong?
My build is quite stiff, every single bearing is really tightened. But on these bits I am having very serious vibrations. The top of the part is better (no hair), but the cut itself is having slight wobble. (on the screenshot below left was cut by 1 flute, and right ones is Diamond 2.1mm)
I wouldn’t use those for plywood, they’re really made for pcb(fiberglass) or carbon fiber panels. The ones you linked to will gum up with wood and glue. Plain old 1 or 2 flute endmills work best for plywood. Plywood really is a shitty material to cut no matter what though. The glues they use are really hard on the end mills.
