Am designing a large piece of decorative wood / bed end to be specific, it is 1900mmx520mm, when i try to generate a gcode, estlcam only codes the middle part of the svg/dxf vector file
estlcam only generates a code for the section circled in red
what can i do to ensure the entire art piece is coded?
I believe that Estlcam has an option to add a “primitive” shape, but I have juste edited the drawing and put a box around the outside, which works well.
