The printers are spitting out some Primo parts here! Kinda excited to tinker with another machine again. We’ve got a standing order starting up for a regular supply of ice cups to a local hotel so I’m going to shrink down the current MPCNC and purpose build it for the ice cups using hard endstops and no homing so I can run it off a Mini. Is there any reason I can’t use dual shaft steppers and run the backside of the stepper across to a bearing mount on the other sides of the X and Y?
The steppers that are closest to 0,0 are the ones most exposed to the snow that blows out of the cuts and during our last order the X and Y endstop switches iced up and froze on me preventing homing until we figured out the issue and thawed them. If I run the dual shaft steppers on the far sides of the X and Y they will stay clear of the blowing snow and with no homing switches - no switches to freeze up. I’ll also be fashioning some sort of cover to keep the steppers from too much exposure to the snow. Electronics will be enclosed in a heated (light bulb) something or other. And I’m contemplating running heat tape through the tubes so they don’t ice up which will only work if they transfer their heat through the tubes to the bearings.
I’m actually going to measure up the machine size requirements and see if I can’t find a chest freezer to drop the machine into. Cut a plexiglass window into the lid above the machine so I can monitor what’s going on and run the electronics outside of the freezer.
Any thoughts/concerns I’m not seeing clearly here?
