Hello, I’m new on V1 Engineering, i hope to put this topic in the right place.
So the deal is, I’m struggling to activate the Dual_Y on Marlin.
The board in the case is a MKR Gen L V2.1 whit TMC2130 SPI drivers.
I already set the #define Y2_DRIVER_TYPE TMC2130 and the #define Y_DUAL_STEPPER_DRIVERS, got no luck at all.
Tryedchange pin of E1 to Y2 on ramps.pin too but got TMC connection Error.
Can please anyone help me.
The printer in the case in a transformation of a CubeProDuo in a Marlin 3d Printer.
That usually does the trick. You shouldn’t have to mess with the pins if you are not using all the drivers. It chooses the next available driver. So if you had EXTRUDERS=1, The first dual driver would be E1.
What did you try and what didn’t work? Just went for a move and it didn’t move? Did you try M119? Or M122?
