Found free a DXF file to gCode converter that seems to be working pretty well. I have to add the G1 command before X Y but that’s easy enough. Thought the foamie guys might have a use for it.
All to G-Code Converter Free
[attachment file=71245]
Dxf to gcode is called CAM :)… Is this just for engraving or something?
Wait, whaaaaaat? ha ha!
No, I’m doing a lot of laser paper cutting. Some of the the Pepakura outputs are 20 to 30, 8.5 x 11 sheets (DXF files). Work flow is:
Pepakura –> DXF–> Inkscape –> J Tech Photonics plugin repeat 20 to 30 times
With this, Pepakura –> DXF –> drop folder of DXF files in this converter about 10 seconds later start cutting.
Still tweaking the workflow, but so far so good.
