Ok maybe someone can chime in and help me understand this.
So I don’t use end stops at the moment. Build is a low rider.
At start of gcode I issue G92 based on where the bit is on the cutting piece. So absolute is set at start.
Now I’ve noticed something strange and I am wondering if this is the problem.
So normally I set zero position in estlcam slightly before the boundary of my work sketch so let’s say bottom left corner. Sketch is to the right and above slightly.
In two recent cuts I let the zero be default which was let’s say at bottom left corner again but this time slightly inside the square in sketch.
Now the machine has cut all inside profiles where they should be but on 2 axes the outer square seem to be clipped.
Is it possible that the machine isn’t going left of the start zero position so clipping it? Possibly g92 at very beginning related? It only is in pieces where zero is slightly inside the sketch.
@jeffeb3 any ideas mate?
