I’m sure it’s something wrong i’m doing but i’m not sure what.
When I open a dxf file in estlcam I open it in mm, I have the grid set to 25x25 mm
I believe 25.4 mm is equal to 1 inch? I resize my dxf file in estlcam to be approximately 16 inches by 16 inches
or approximately 400mm x 400mm according to grid … I save the cnc program , load it in repetier and it shows
that it’s about 4 times the size of the area of the “bed”
is there a way to change the scale in repetier of the bed or is my resized cnc program file actually going to
try and run gigantic compared to what it should be
I have not actually tried to run this job yet
I appreciate any info and help
