Greetings all!
I know Estlcam gcode optimization has been discussed before but this is slightly different.
If I set up a complicated carve and define a different tool for carve and carve pocketing (e.g 60-deg V-bit for carve and 1/8" End Mill for pocket) any Machining Order I do other than Automatic (As Created, Optimized, or manually setting the order) will alternate the carve and pocket tool in the gcode instead of bulking all moves with the same tool together. This isn’t useable, unfortunately.
Am I missing a setting?
Is there a way to post process this to clean up?
Should I be doing the carve pocket in a different way?
There are lots of tiny nooks and crannies in the design. Even the carve by itself has a lot of travel as clearout is done independent of the outline.
