Mini Rambo build sourced from the site.
EstlCAM set up identical to instructions.
Have done about 100 cuts without issue.
Same SD card (but also ran the codes through USB and got the same issue)
Inkscape->EstlCAM
Machine has been cutting codes like the first example perfectly.
All of a sudden its creating code like the second example and the machine rapids to place then seems to stop moving or is just moving so slow I can’t tell. Motor just clicks. When I abort the print it takes about 30 seconds for the motor to quiet.
Machine jogs around table without problem.
Thanks for any help.
G90
M03 S20000
G00 X0.0000 Y0.0000 Z0.0000 F2100
G00 Z5.0000 F480
;No. 1: Carve 2
G00 X15.3828 Y16.9845 F2100
G01 Z-0.9072 F540 S20000
G01 X8.1752 Y9.7769 Z-0.0063 F540
G01 X8.1251 Y9.7268 Z0.0000 F540
G01 X15.1826 Y16.7843 Z-1.7644 F540
G01 X15.3828 Y16.9845 Z-1.8144 F540
G01 Z-2.7216 F540
G01 X8.1752 Y9.7769 Z-0.0188 F540
G01 X15.1826 Y16.7843 Z-3.5287 F540
G01 X15.3828 Y16.9845 Z-3.6288 F540
G01 Z-4.5360 F540
G01 X8.1752 Y9.7769 Z-0.0313 F540
G90
M03 S24000
G00 Z5.0000 F480
;No. 1: Part 1
G00 X-1.5875 F2100
G00 Z0.5000 F480
G01 Z0.0000 F3.000 S24000
G03 X-1.2828 Y-0.9352 Z-0.5000 I1.5875 J0.0000 F3.000
G02 X-1.5875 Y0.0000 Z-1.0000 I1.2828 J0.9352 F3.000
G03 X0.0000 Y-1.5875 I1.5875 J0.0000 F15.000
G01 X609.6000 F15.000
G03 X611.1875 Y0.0000 I0.0000 J1.5875 F15.000
G01 Y310.8277 F15.000
G03 X609.6000 Y312.4152 I-1.5875 J0.0000 F15.000
G01 X0.0000 F15.000
G03 X-1.5875 Y310.8277 I0.0000 J-1.5875 F15.000
G01 Y0.0000 F15.000
G03 X-1.2828 Y-0.9352 Z-1.5000 I1.5875 J0.0000 F3.000
G02 X-1.5875 Y0.0000 Z-2.0000 I1.2828 J0.9352 F3.000
