I’d like to share my small but growing toolset I use for Fusion360. I have yet to truly dial in these tools but they seem to work well so far.
I took some cheap HF micrometers and measured some equally cheap end mills, spiral cut, and a nice bosch straight bit - took those measurements and plugged them into my local tool library.
the attached file can be imported into Fusion360. I am not sure if it will also import the holder that I use for the tools (a 500w 10k rpm from china).
If we could share tools, it would eventually make things easier for all of us.
Here are the links to the mills I have in this file:
10 Piece Diamond Point Rotary Grinding Set from HF:
3 Piece HSS 1/8" Spiral Cut Bits:
Bosch 3/16-in Carbide-Tipped Straight Bit:
https://www.lowes.com/pd/Bosch-3-16-in-Carbide-Tipped-Straight-Bit/1082821
errr… I tried to upload the file “tools.tools” file but the forum will not let me.
