I’m trying to get G38.2 to work. I started with the firmware from the firmware page and made a couple of changes to the Configuration.h and Configuration_adv.h files and then flashed the firmware. The commands now trigger an action. However, the axis doesn’t stop when the touch plate is hit. It appears to be a known bug in the 1.1.0-1 firmware (I think that is the version from the firmware page). It has been fixed with firmware after 1.1.0-RC8 .
The way I see it I have four options:
1 . Jump to the latest firmware from the Marlin page and try to change the settings in Configuration.h and _adv.h to match those from the V1 firmware page.
Use the latest firmware from the Allted/Marlin github page and make the probe changes to those configuration.h files
Ok. I went for option 2, Downloaded MPCNC_MRambo_T8_16T_LCD branch from Allted/Marlin github and made a few changes to configuration.h: defined FIX_MOUNTED_PROBE and setting INVERT_X_DIR, INVERT_Y_DIR, INVERT_Z_DIR to all true (that was easier than flipping the connectors) . In Configuration_adv.h, I defined G38_PROBE_TARGET.
Sadly, same effect G38.2 moves the axis (X, Y or Z), but doesn’t stop when the Z endstop is triggered. Nice splash screen on the v2 firmware though.
If I did something obviously wrong or if I missed a setting, let me know. I’ll continue to work it.
Try M119 to see your end stop status, then manually trigger the connection and try it again. You might have a wiring issue between the z plate and your board or between the bit and your board.
Solved, but it wasn’t pretty and Marlin has a bug here I think. From some research it appears this “bug” has been fixed and then comes back often as the other end stop and bed leveling features evolve.
For future reference: I made the changes as above and then had to edit the endstops.cpp file to change the #if ENABLED(G38_PROBE_TARGET) section of the code to read the Z_MIN instead of the Z_MIN_PROBE and comment rest of the conditional. This is because I don’t think Z_MIN_PROBE is actually getting set when Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN in Configuration.h is set.
You should be able to use newer versions of marlin without issue. I found that manually configuring Z_MIN_PROBE_PINfixed my issues. Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN seems buggy and doesn’t set the appropriate pin to be monitored by G38.
With the latest firmware (Ryan updated a couple weeks ago) it is possible to get this working with just Configuration.h and Configuration_adv.h, no changes to any cpp files are necessary.
There does appear to (still) be some weirdness around Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN, and as far as I know this must be disabled (even if using the zmin connector on the board).
