A shop sign I made for my father for his birthday. Designed in Illustrator and programmed in Estlcam.
This made from a panel of solid 3/4" Cherry. The CNC milling consists of 3 separate programs - the saw and border milling 1/16" deep with a 1/8" down cut, a 1/16" deep chamfer with a 60° V, and a V carve and 45° 1/4" deep outside chamfer with a 90° V.
Once the milling was done I used a 2" wide beast of a chisel to give a hand hewn look to the background. First across the grain to tear out the material and then with the grain to produce distinctive chisel marks and clean it up.
3 coats of shellak were applied and then gold leaf was added to V carve and the border. 3 more coats of shellak were added to seal. Wax and buff.
I really like how the gold leaf gives dimension to the V carve and it was relatively easy to apply it. Very happy with the results.
