I am using:
Rambo 1.4 board
Dual end stops
Mac computer
Repetier desktop
Plugged LCD into machine, screen lit but blank. Wires switched around no difference.
Going through forums, I see the #define controller issue and define BAUDRATE.
I have lost a lot of data so I’m starting from scratch again. I don’t really know my way around the back end of electronics so really simple advice please.
Machine originally bought/built in 2017, haven’t touched this end of it since then.
I downloading Arduino again and installed the Rambo driver from reprap.org.
Installed ‘V1CNC_Rambo_Dual-2.0.7.2-src.zip’
Opened Configuration.h file and changed the lines for controller and baudrate as advised here and here. Compile and Uploaded.
I then home the MPCNC and it doesn’t recognise the end stops, tries to keep moving when it’s at it’s origin.
Edit: Also, the LCD still didn’t work at this point.
Do I need to install all the drivers on the ‘Boards Manager’ menu in Arduino, or does it look like I’ve done this right?
Both were bought from V1. Plugged the LCD out of the box and the screen lit up, but blank.
EDIT:
No extras running on my machine.
I followed all the instructions you linked as best I can.
Photo attached of wiring before the LCD was plugged in, I can get another one if needed. I appreciate you’re trying to help out people on this every other day.
Make sure port 1 is to exp1, and 2 to 2. From there it is 50/50. Unless you flashed the board. If so use my links and flash the new firmware with platform io.
