hi
I tried to make milling of aluminium. I read this manual and saw the video of estlcam referred on the page.
So I took this model https://www.thingiverse.com/thing:2726668 and tried to make gcode for milling 40mm diameter coin using 2mm carbide tool.
[attachment file=71860]
But i found that it looks like estlcam doesn’t generate spiral evolutions during milling (as trochoidaladaptive milling should do).
Am i understood right that I can achieve trochoidal miiling with estlcam only with 2D models (DXF, SVG) and can’t get it at all for 3D (STL)?
Or I just did something wrong (as example didn’t enabled and option in estlcam)?
I tried both “free machining” and “block machining” - both don’t work as I expected.
And yes, gcode generated from DXF is as I expected
