Hello everyone, I need assistance and I’m running out of time available to work on this.
I can’t seem to successfully home the device correctly. All endstops have been wired NC, ran the M119 command, confirmed they’re open until “TRIGGERED”. I did the rectangle, Pythagoras theorem, figured out I was off 3.125mm. Moved a block a tooth to reduce it to 1.125mm, set my offsets in repetier using M666 X1 Y1, saved using M500. Tried to home it again and zero change. Z homes perfectly, can’t home X or Y.
So I updated the firmware, adjusted the offsets in the adv configuration file, saved, verified, flashed the new bios. Tried it again to no prevail.
My surface area is 490x490, technically bigger but I settled with that for now, z from zero can go 65mm. All steppers are working correctly, I can connect to the software just fine, lcd screen works, and like said previously all endstops read open until “Triggered”.
