JDGreen's 600mm x 600mm MPCNC
First of all let me say a huge thank you to Vicious1 and everyone on here who has made and improved on the MPCNC.
I have had the most fun I can remember this winter putting this together.
I was looking for a little bit bigger work area and I really wanted to try out a laser cutter/engraver.
I started with a 24" x 24" build area making the frame approx. 30" x 30"
I bought a plug and play kit from JTPhotonics.
The thing I am most proud of is the curtain that shields the entire work area and bystanders from the laser.
It bolts on to the totem corners and uses 1/2" EMT for the rods.
The curtain is amber welding screen that I bought from ULINE
ULINE Orange Replacement Welding Screen
It was actually made by jtillman.com and has a great tech data sheet.
Thank you again for the fantastic design, your generosity in sharing it with us, and for the support of this entire community
JDGreen
Welding-Screen-Performance-graph-orange.pdf (16.9 KB)
Here is the STL file for the Curtain Corners if anyone is interested.
Laser_Curtain.zip (87.7 KB)
Looks good.
Good find on that welding screen, I think I need to pick some of that up.
