I am suddenly getting the following error after starting up.
Killed.
Printer halted.
please reset
plus a loud sustained beep from the lcd. I unplugged the lcd and was able to connect with cncjs but a few seconds after connecting I get a similar error in the console. Any ideas?
302… 2.0 Bugfix… It’s the one that shipped with the board. Full Rambo but not dual firmware. I’m using cncjs connected via usb. It has previously worked fine on this setup. I can’t get far enough to load any gcode. It just goes to the error within 2 seconds of booting up. All the fuses look ok although I’m not sure how the little ones look when blown.
It sounds like somehow pin 80 is shorted to ground. The button on the LCD should normally be configured to the KILL function, but if it still triggers the kill function with the LCD unplugged then it can’t be the LCD. My LCD button is normally open and shorts one side to ground when pressed.
If you can double check that you have the problem when LCD is disconnected, and that you are running the RAMBO firmware, you can try this:
download the rambo firmware and go into Marlin\src\pins\pins_RAMBO.h
on line 167, comment out "#define KILL_PIN 80", i.e. change it to "//#define KILL_PIN 80"
flash firmware and see if it makes a difference. It should disable the kill pin (supposed to be on the LCD but could be shorted somehow.)
Hello… Thanks for the idea on disabling pin 80. I tried to flash the firmware, but it failed. If I open up the Serial monitor in Arduino IDE, i get the same kill() message shortly after powering on the board. Here is the error when trying to upload the firmware:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: “RAMBo”
sketch\src\lcd\ultralcd.cpp: In function ‘status_printf_P.constprop’:
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
Multiple libraries were found for “U8glib.h”
Used: C:\Users\Brian\Documents\Arduino\libraries\U8glib
Not used: C:\Users\Brian\Documents\ArduinoData\packages\rambo\hardware\avr\1.0.1\libraries\U8glib
exit status 1
Error compiling for board RAMBo.
Just to be clear, I’ve ruled out the LCD by completely disconnecting it. I get the same kill error in the attached pics above in cncjs and Arduino serial monitor on 2 different PCs. This error happens upon bootup. I am unable to issue any commands after it occurs. It appears to also be reason I cannot flash new firmware to it.
I hear what you’re saying. I agree it’s not the LCD.
The “internal compiler error: Segmentation fault” is something I’ve seen on the newer Arduino releases and it’s annoying. Sometimes if I try multiple times it will succeed. Another option, also annoying, is to try reinstalling Arduino 1.8.9 and the ug8lib and extra boards as described in the instructions (https://www.v1engineering.com/marlin-firmware/). You could also try the non-windows-store version, which is just a zip file you can run without installing.
If you compile and you see error without an “internal compiler error” then post that here and we can diagnose more from there.
After reinstalling Arduino IDE (non Windows Store version) AND turning on verbose mode for compilation and uploading, I was able to get the firmware to load. I was then able connect via cncjs and jog the machine around. I thought GREAT problem resolved… and decided to plug in the LCD again. The LCD now boots up to the normal screen however the alarm is still blarring from it. Is that another PIN i need to disable?
I don’t know if this will help or not but the last time I saw that happen it turned out to be one of the LCD cables was backwards. That is what caused the Kill and the beeping. But since you said it happened with the LCD detached I am not sure. If they two cases are related.
no idea how it got shorted… i had the case open because I was installing a switch between the power supply and board. Yes power was unplugged when I did it.
I would agree with faulty board. Did not change or touch anything as far as the boards goes. It worked in the evening. and when I started it up in the morning I had the error. As I said the only thing that was different I had an SD card in it when I started up. I ordered a new display ($15) and will see if that solves the problem. I need the display for tool changes…
I am going to take a guess the wrong board was selected and was deployed as a RAMPS and not a RAMBO. I just ran into the same exact issue and I realized I was following the wrong firmware update procedure.
I got the same error. I switched up the starter button cabels on the psu controller, the yellow to open and the blue to close, that was the problem, and it is working now.
I got the same error. I switched up the starter button cabels on the psu controller, the yellow to open and the blue to close, that was the problem, and it is working now. That was almost two days…
