Need some advice. Where my X and Y exit the gantry bearings, on the end near the long central screw the bearings held by that screw do not touch the conduit the other two do. At the other end of the gantry all 3 bearings for x and y touch. This is allowing the X and Y crossbeams through the gantry to wiggle at the loose end.
Any ideas why these would be away from the conduit? Suggestions on how to adjust?
Use it a bit and “break it in” then take apart the gantry and the second time around it usually is fine. Make sure tho follow the instructions real close and watch for the same issue the second time around, it should not happen.
