Hi,
I did my first cut in 16mm mdf at 20mm/s feed and 1mm per pass. on about the 10th pass both the x and y started skipping and machine jammed.
I tried different feed rates even as low as 10mm/s with varying results. Sometimes jamming, and sometimes not.
It is almost as though the x and y steppers are not as strong as I had thought they would be, which got me thinking.
My stepper motors have a current per phase of 2a, so that would be a vref on the DRV8825 of 1v (I have heatsink and active cooling on drivers). This would be ok for the z, but does this mean that the x and y motors only get one amp each? Is this why they seem under powered?
Cheers,
Damien
