I need to build a table for my LowRider. I haven’t quite figured out what I would like to build for a table. Somewhere on here I came across this “folding workbench for workshop” table. I like the fact that you can fold it up and put it away.
Can the LowRider 2 be stored in the vertical position? I’m thinking I could have two dowels to rest it on and secure it with a strap or something.
Looks like what I am planning, using the same sketch as my initial starting point. Your woodwork is much nicer than mine, still, it should hold up to a bit of use/abuse.
Interesting concept… I’m following along here as I need to start my table build.
I like the idea of fold away but am also interested in a quick disconnect system to remove the LR2 from the table. I’m thinking along the lines of a 3D printed latch that locks each belt end stop to the table. I’m also interested the folding mechanic of some table tennis tables
Love this table and had something similar in mind for a long overdue lowrider build. You don’t happen to have any plans for that table do you? I’m especially curious what size you used for the folding brackets and whether you’ve found it to be stable enough.
I don’t have plans but the base is 2"x4" - 36" x 48" sat on casters, the 36"s are sat on the 48"s you can see that in the pics, the 2 legs are 4"x4" sat on the 36" in the center, these are 26" long, there is another 2"×4" running between the legs, each leg has a 2"×4" support at the back these are 18" long. For the table I used full sheet 1/2" MDF on the bottom then picture framed that with 2"×4" then put 2"×4" width ways 16" between centers another sheet on top (its heavy).
This is extremely helpful. Is there anything you’d do differently if you were to do it again? Do you think the table is stable enough for uses beyond the lowrider?
That looks great! Do you feel like having the pivot supports centered in the base is necessary or could you reduce the size of the “under table” part of the base to get the folded footprint smaller?
How are you holding the lr2 to the table when it’s stowed?
I feel you could easily reduce the pivot to base length… but you’d need to do some calculations in advance before making the cuts. I wanted a large base box for storage purposes of tools etc… My vac fits in it as well. Regarding securing the LR2 - I have drilled two holes through the table, one at each end of the X axis tubes. A long bolt passes through a piece of ply that pushes against each tube holding it securely to the table. I have a couple of wing nuts under the table to do it up hand tight so not too mcuh pressure is applied to the tubes as I not want to go bending them.
The under table shelf I don’t really like as it hinders the possibility of mounting a table saw beneath the table which I’d really like to explore. Having said that the problem then arises of having the table saw poistioned very high up when the table is stored in its vertical position which is unsafe.
note: I’ll post a few pix in my build post of my current setup.
